Finding difference between two dates and adding it to other date
My requirement is to find the difference between two dates in seconds and add it to another date. Here I am facing following two difficulties.
1. The function "DateTimeDifference" is returning the result in double which cannot be passed to "addToDate" function as it does not accept double values.
2. If I catch the result of "DateTimeDifference" in integer property it has range limit which I cannot use in all scenarios.
How to solve this?
Thank you,
Adithya
Hi Aditya,
There are @differenceBetweenDates() and differenceBetweenDay() function which returns the difference between two dates and days (as int value). You can capture it as decimal and then pass the same to addToDate function.
