Standard Chartered Global Business Services
Posted: Jun 9, 2017
Last activity: Jul 19, 2018
Last activity: 19 Jul 2018 15:45 EDT
Multiple activities with same interaction key
Would it possible to have multiple activities with same interaction key (using Interaction Framework) run in parallel?
You can perform parallel processing within an activity, however you cannot have multiple activities executing at once. In addition, and activity can be responded to by multiple automations and multiple projects. The ActivityStarted event will fire in all of your projects at the same time, so all of the projects can respond to it and take action in parallel. When all of those threads have been completed, the next activity in queue would then fire its ActivityStarted event.
Calling StartActivity doesn't actually initiate the activity. It merely puts the activity on the queue to be executed as soon as its turn in queue is up. If there are no activities in the queue, then the ActivityStarted event will fire right-away. If there are activities in-queue, then the activity will be added to the queue and executed when it has reached its place in-line.
