Verizon Wireless
Last activity: 31 May 2017 23:20 EDT
Issues with the embedded Cassandra - DSM 722
Hi Team,
We are facing issues with the Decision data store in the Decisioning services wherein after adding the D-Node , the connection with embedded Cassandra is getting failed (STATUS - JOINING_FAILED) [Screenshot attached]
I have enabled the following logger com.pega.dsm.dnode.impl.cassandra.Cassandra and the below mentioned errors have been observed.
2017-05-26 08:47:02,097 [.PRPCWorkManager : 1] [ STANDARD] [ NBAHub:17.23] (rvice.operation.StartOperation) INFO rtdadmin - Starting service [DDS.Default] in client mode
2017-05-26 08:47:02,106 [.PRPCWorkManager : 1] [ STANDARD] [ NBAHub:17.23] (rvice.operation.StartOperation) INFO rtdadmin - Successfully started service [DDS.Default] in client mode
2017-05-26 08:47:09,009 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] (rvice.operation.StartOperation) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Starting service [DDS.Default]
2017-05-26 08:47:09,326 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) DEBUG saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Found java version [SemanticVersion{1.8.0}]. Will continue to start Cassandra
2017-05-26 08:47:09,348 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Cassandra instance is already unpacked. Skipping unpack
Hi Team,
2017-05-26 08:47:09,351 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Cassandra is not running. Will start it
2017-05-26 08:47:09,352 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) DEBUG saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Starting DNode bootstraping phase
2017-05-26 08:47:09,352 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) DEBUG saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Overwriting Cassandra yaml file
2017-05-26 08:47:09,357 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) DEBUG saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Overwriting Cassandra logback file
2017-05-26 08:47:09,358 [1df.cached.thread-15] [ STANDARD] [
2017-05-26 08:47:09,358 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) DEBUG saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Starting cassandra as a child process...
2017-05-26 08:47:09,369 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Started cassandra as a child process
2017-05-26 08:47:09,369 [dra-Output-Monitor-0] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Redirecting cassandra logs to PRPC
2017-05-26 08:47:10,388 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] ( impl.cassandra.Cassandra) INFO saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@xx- Waiting for Cassandra startup. Current state [NOT_RUNNING] CQL port listening [false]
2017-05-26 08:47:10,396 [1df.cached.thread-15] [ STANDARD] [ NBAHub:17.23] (rvice.operation.StartOperation) ERROR saswirtdzad01.sdc.xx.com|XX.XX.XX.XX ABC@vzw - Cannot start service [DDS.Default]
Pradeep Pydi.
***Updated by Moderator: Marissa to mask proprietary information***
