CGI
Last activity: 22 Sep 2017 3:26 EDT
Open Case closing issue
We have above menu bar in our application.
We open case from "Create/Modify Customer" menu.
Issue/Requirement: On click of any other menu like "Portfolio Reports" or "Work Item Queue", Opened case should be closed.
Can someone provide solution.
Thanks in Advance!
Hi Rajasekhar,
You can run the script by providing the function name("pega.u.d.closeWork") in the field as below:
or you can use "cancel" action on click event in the action tab of the menu item.
Vikash
Hello Rajashekar,
If you open any rule after clicking the portfolio reports or Work Item queue, it will close the previously open rule from UI and clipboard if you are not using the dynamic container or tabbed layout.
CGI
Hi Praveen,
I am not able to understand. Could you please explain so that I can check in my application.
Thanks in Advance!
Hi Rajashekar,
After clicking the Menu Item, if you are opening any page than it will close the previously opened page/case from UI and open new page/case. Could you please send us the design time screen prints from Menu configuration.
Praveen
CGI
Please find the menu design
I have clicked on Create/Modify customer menu and opened a case. when I click on any other menu item e.g. work item Queue>All work items, it displays report but Current open case is not closing and clipboard page is not removed.
Hi Rajeskhar,
If you are using a dynamic container or tab group layout you can restrict the number of documents you can open.
In container or Layout properties you there is an option of the Maximum documents used.
If you want single document at a time. While configuring the dynamic container there as an option called Mode where you can select Single Document.
Please let me know if you have any queries.
CGI
Hi Pooja,
I do agree with you, on single mode Dynamic container. We are using mode Multiple with 16.
Currently we are doing below steps
- clicked on Create/Modify customer menu and opened a case.
- when I click on any other menu item e.g. work item Queue>All work items, it displays report
Without changing Dynamic container, can we close Current open case and clipboard page is not removed i.e. on click of "Queue>All work items".
CGI
Hi Pooja,
CGI
CGI
Without changing Dynamic container, can we close Current open case and clipboard page is not removed i.e. on click of "Queue>All work items". Please go through above query.
CGI
I think calling the below script would close the current work.
pega.u.d.closeWork
-Saikat
CGI
Thanks Saikat.
Please share the details to use pega.u.d.closeWork
Call this script from button onclick action.
-Saikat
CGI
Sorry for delayed response.
I am not clear, Onclick of menu item, we have to close the case.
Please share the details to call the workclose script.
Thanks in Advance..........
CGI
Hi Saikat,
CGI
Hi Saikat,
CGI
Hi Saikat,
CGI
Hi Saikat,
Hi Rajasekhar,
Vikash
CGI
Thanks.........
