Amendment needed regarding Validating User Data exercise on CSA 7.2
I've been teaching the CSA course a few times now and every time we come across an issue with the Validating User Data exercise.
In the first section of this exercise it states to;
- In the Application Explorer, expand Onboarding > User Interface > Section.
- Click the CollectEmployeeInfo_0 section.
You are then advised to change the 'Required' on each property to 'Always'. However this doesn't work due to the fact that by this point in the exercises there is a 'Section Include' for the Employee information - namely a section called CollectEmployeeInfo_0_Employee. This is clearly created at an earlier exercise but it impacts this exercise - most specifically that if the trainees complete the steps as advised it doesn't actually change the 'Required' property on each field.
I know the solution is to open the CollectEmployeeInfo_0_Employee section and make the changes there - I just think this needs to be noted in the exercise to avoid this confusion in the future.
Thanks for your time,
Daniel Jefferies
