UnitedHealthcare
Convert VirtualObject to WebControl
In Robotic Automation 8.0 there is an "All" property on web pages in Universal adapters. According to the documentation it contains "a collection of all the HTML elements contained in the webpage." This seems quite useful. I'm at a point where I can read the values of any element on a page. However, I can't figure out if there is a way to convert the elements to WebControl's (or some other type of object) so I can raise events and set attributes.
The All.AllItems property returns array of VirtualObject's. Is there a way to convert a VirtualObject to a WebControl or similar object that allows changing the attributes and firing events?
You need to cast it to an OpenSpan.Adapters.Web.WebBase.Targets.VirtualHtmlElementTarget. That will allow you to interact with all of the properties of the control. I just used a Label to do my casting.
