Verizon
Last activity: 18 May 2017 4:07 EDT
Hard Deleting Work Object Data using SQL
Our client wishes to implement a clean up process by using SQL queries to be run as and when required.
So, we have identified the following tables from which thw work object and its dependent data to be deleted.
PC_DATA_WORKATTACH
PC_LINK_ATTACHMENT
PC_ASSIGN_WORKLIST/PC_ASSIGN_WORKBASKET
WORK OBJECT TABLE
Can you please let me know if hard deleting the data from these tables would be enough or we have to consider any other tables ?
Also, what additional processing should we consider while performing this operation.?
Thanks.
