Pega 5.2 to Sharepoint Integration
Would anyone help me with how to Integrate to Sharepoint in Pega 5.2 to Extract and Sent the attached Documents to Sharepoint from Pega?
While this is something that I haven't personally done before, the below post looks like it may have some helpful information:
https://collaborate.pega.com/question/sharepoint-integration-mfamulti-factor-authentication
Hope this helps!
-Kurt
Thanks Kurt :)
In Pega 5.2, I wanna Expose the pyAttachStream property. In modify Database wizard what Varchar length against tha column/property should I give, so as to accomodate the whole ByteStream?
In Pega 5.2, I am trying to Expose the pyAttachStream property. I have created the column with a datatype as Varchar(max), But the prdbutil-Resave pega instances utility is not able to extract the values. it is failing for almost every record.
Would anyone help. Thanks in advance.
