( platform.message.CoreMessage) WARN - The message exceeds recommended size of :8000.
Does anybody know why the above mentioned warning is generated in our PEGARules.log and how we might get rid of it?
We are running Pega 7.2.2 on Websphere 8.5
Kind regards,
Arjan Maus
that works in prconfig. Alternatively, you can use DSS with the setting purpose like 'prconfig/messaging/core-message/message-size/default' with owning ruleset as 'Pega-Engine' - the DSS is preferred in general as it applies to all nodes within the pega cluster.
This is the javadoc from the CoreMessage class:
CoreMessage is the implementation of the kernel level message api. It is just a warning regarding the message size, which is controlled by prconfig setting "messaging/core-message/message-size" with a default value of 8000 bytes.
Hi Kevin,
I'm a colleague of Arjan and I've checked our prconfig.xml and this line is not set, does it look like this?
<env name="messaging/core-message/message-size" value="8000"/>
Or is there a Dynamic system setting which is possibly better so we don't see this Warning anymore in the log?
Hi Kevin, if its just a warning can we increase the value till the warning goes away and what would be the impact if we increase to much higher limits.
May be explanation of what it actually does will help.
Dalbir
We encountered the exact same warning and I understand that it can be properly addressed by setting the configuration. But out of curiosity, what does this warning message actually implies? And is there any significant impact on the system?
Raymond
Hi Team,
Even we are getting same Warning despite setting the value to "32000". Could some one please suggest what does this warning imply and what can be the max value and what would be the impact if we increase to value beyond a say 64000.
Dalbir
The DSS only sets the threshold value. When the kernel level CoreMessage API, handles a message above the DSS value, then a Warning is raised.
Therefore your system is already handling message size above 64000, it’s just a matter of increasing until you stop receiving the WARNING message. Or you can ignore this Warning.
