Virtusa Consulting Services Pvt. Ltd
Posted: Mar 30, 2017
Last activity: Apr 18, 2017
Last activity: 18 Apr 2017 9:30 EDT
requirement to use the client API which are based on RESTFUL services
We are using PRPC 6.3sp1. We have a requirement to use the client API which are based on RESTFUL services. Client APIs are secured using OAuth 2.0 authorization framework.
In order to invoke the services using OAuth, 4 types of grant types are available (Authorization Code/ client certificate/Implicit).
Show More
In order to invoke the services using OAuth, 4 types of grant types are available (Authorization Code/ client certificate/Implicit). We would need to make two service calls (Get the token using first API Call, Use the token and make second API call for the actual request)
Does PRPC 6.3 supports OAuth 2.0 framework?
Does all the grant types are supported?
If we have to use client certificate, how to proceed with the client certificate approach in PRPC 6.3 SP1?
Any thoughts would be really appreciated.
Ravikumar
Show Less
