PDF Styling Issues when run via agent
I am having issues with pdf styling for Work items.
Using Pega OOTB activities HTMLTOPDF and ATTACHTOWORK to attach a pdf to the work item.
If I run the activity via Declare Trigger, the styles are correctly applied.
If I use Queue-For-Agent, no styles are applied to the pdf.
If I run the activity from designer studio, the pdf is generated with grey background.
Environment : Pega 7.1.9
Already tried below work around but it does not work for me.
https://pdn.pega.com/community/product-support/question/pdf-generation-issue-through-standard-agent
The below link says this issue was fixed in 7.1.6 , but I am still facing this issue in 7.1.9
https://pdn.pega.com/support-articles/export-pdf-generates-pdf-files-without-any-styles
***4/7/17, edited by moderator, Maryrita: moved from Upgrade Center to Product Support***
