Stratosphere Technical Consulting
Last activity: 1 Mar 2017 18:53 EST
No access permission for report when invoke report through Data page
I have created a data page with the type as List; for the source, I have select Report Definition. The data page's scope is node. The report definition does not have any value in the Security privilege setting. I am able to run the report just fine by itself. But when I run the Data Page, it gives me an error saying "No access permission for the report". If I change the scope to Thread, I will not get the permission error. Why is that? I like to use node level as scope so that the data page can be used by all users.
Thanks in advance.
***2/27/17 updated by Maryrita, moderator: moved to Product Support from Applications***
When using a Node level data page you need to specify an access group on the Load Management tab. Check to make sure the access group specified has access to the report definition.
