export data in excel format
I need to export some data in Excel format.
The structure of the output excel file should be the following:
username username1 username2 USERNAME3 ...
description description1 description2 description3 ...
The file must be formatted by row and not by columns.
Could you help to define the template and provide me the info to do so.
Attached the trial template which I called for only three columns. I would like to modify the template so you can export an undetermined number of columns.
Thank you very much.
