Societe Generale
Last activity: 1 Feb 2017 8:41 EST
Load-DataPage Requester type
Hi Team,
We are using Load-DataPage method in an activity A1 and giving a data page to load which is sourced with Activity A2. after running the main activity A1 i see datapage in the clipboard but no values are populated and the classtype of the datapage is classless.
I see issue is because , activity A2 is having Require authentication to run checked, when i uncheck this and run i see activity my use case works properly.
Can someone explain what kind of requestor does the Load-Datapage created
***Updated by Moderator: Marissa to close thread per private discussion with author of post***
I guess this method spins off an asynchronous requestor of batch type.
