changing tab Name
How to change the title of the tab once opened. Please Check the screenshot for further information.
Thanks;
Thanks;
Is that a static tab or the tab opened in Dynamic container of the Tab Group ?
For Dynamic Containers, pyDocumentTitle property is used to override default titles. You can try creating a declare expression on pyDocumentTitle property (to set to pyLabel) and you can set the pyLabel property to a desired value in a pre-data transform.
Hope this helps. Let me know if you have any concerns.
Best Regards,
Mounika
Please check the screenshot below to show the Container called conta.png once ModuleManagemet action is pressed as shown in Modules.png.
Thanks;
Please have a look on the below article :
https://pdn.pega.com/community/pega-product-support/question/change-title-new-work-tab-instead-pyid
Let me know if it helps.
Thanks.
