Virtusa
I'm using the below code in non auto generated HTML but it opens the new work in new window and not inside the portal
I am using the below code in non auto generated HTML but it opens the new work in new window and not inside the portal. I have included my section in pyPortalContent section.
Please advise.
1. In a non-auto generated section, include a JS file. This JS file would include the API call.
<pega:static type="script" app="webwb" moveToEnd="true"> // this is how we include a JS file
<pega:file name="TempTestFile.js" />
</pega:static>
2. In the TempTestFile.js file have the below code
pega.u.d.attachOnload (function(){pega.desktop.createNewWork("Good-FW-gcsFW-Work", 1, "NewWork")},true);
here in the API pega.desktop.createNewWork(strClassName, harnessVersion, strFlowName, flowParams) :
strClassName - class name
harnessVersion - harness version, set it as 1
strFlowName - flow name
flowParams - if any parameters are passed in the flow, then you can pass it here in the format : ¶m1=value1¶m2=value2
where "&" and "=" are delimiters
There is another way you can use the API call :
In an HTML page(non-auto generated section) you can create a button. When you click the button, a new work item would be created.
<script>
function buttonFunc(){
var safeURL = new SafeURL();
safeURL.put("className",'PegaSample');
safeURL.put("flowType","BUG64630");
Please advise.
</pega:static>
<script>
safeURL.put("HarnessVersion",'1');
safeURL.put("Param1",'xxx');
safeURL.put("Param2",'yyy');
safeURL.put("Param3",'1234');
safeURL.put("Param4",'k4567z');
pega.desktop.createNewWork(safeURL);
</script>
<button class='buttonTdButton' alt='' title='' onclick="buttonFunc();">NEW_WORK_BUTTON</button>
***Updated by moderator: Lochan to create new post from this comment, add topic categories***
