First Tech Federal Credit Union
Last activity: 9 Jan 2017 11:27 EST
What should be standard guidelines for Applies To Class selection for new rules created using Connector and Metadata Acc, Wizard?
Hello Team,
I am trying to create a file listener which will read xml file and create a WO once file is processed.
Point 1. I followed some standard steps like importing XSD through connector and metadata accelarator wizard which will generate all the properties and classes along with parse XML rule. All theses generated rules have been defined under Int- class as a standard practice.
Point 2 Now to create a WO, I am giving the primary page and class of WO in Service File rule as well as the processing activity from same WO class.
How and where can I best define my all the rules along with Parse XML generated in Point 1 so that Service File rule reference the Parse XML in Request tab when the primary class mentioned under Service tab of Service file rule is Work- class?
Please advise.
Rushikesh
