Synechron Inc.
Unable to find the Excel connector in Pega Robotic studio
I am unable to add the Excel connector from the toolbox and also I have tried searching for it in Global cache and its not showing up in Microsoft office category. I have latest office 2013 version installed. Kindly help me out in this problem.
The Office dlls should be placed in the Pega Robotics installation folder.
Did you install the Office support when you installed Studio? This is required. The connector is found in the Pega Robotics Connectors section of the Toolbox.
If for some reason it is no longer there, right click on the Toolbox and select Choose Items. This will bring up a dialog to add the connector to the Toolbox.
Note that the OpenSpan.Office assembly must be present - this is installed when you add Microsoft Office support at install time.
Capgemini
BR
Hi Jeff
The "Pega Robotics Connectors" is not present in my Toolbox.
How can I add this?
Thank you.
Hello!
Thank you for posting your query on PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write a Post button that’s available on the top right pane of this page. Once created, please reply back here with the URL of the new post.
We have also sent you a private message opening up a communication channel in case you have any further questions.
Thanks!
Synechron Inc.
Hey Jeff,
Thanks for your response. I installed office 2013 after I installed studio, since I had office 2007 version which normally doesn't supports EXcel connector.
Do you think that is the problem which is not allowing the studio to recognize the connector??
Thanks and Best Regards,
Madhukar Ganesh Chatra
Northbridge Financial Corporation
Hi Madhukar,
how did you get Micorsoft Excel connector? Office dll's file should be placed to where?
Ramar
Read the rest of the post.
The version of Office you have installed on your machine must match the support you have installed with Robotics Studio. If you re-install Studio with Office 2013 support you should be fine.
Synechron Inc.
Hi Jeff,
The issue got resolved and I just copied the Office 2013 dll's to their root folder.
I really appreciate your help and time.
Have a nice day.
TCS
Can you please explain in details how u did this :)
The install folder for 8.0 contains sub-folders with the dlls for each version of Office.
Copy the contents of the correct sub-folder into the root folder to switch versions.
Accenture
Hi Jeff. When i try to add the DLLs from the directory : 'C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\Office2013'. I get the error below :
even after this the dll componenets are loaded and are visisble in the tool box, but when I try to add them in the automation , doesnt work.
Please help.
Virtusa PVT Ltd
I am getting the same issue.. Did you get solution?
Perficient
Hi
we are not getting the connectors.as per your solution i want to know in which root folder office dll file have to save.
Please help me in this problem.
Thank You.
Perficient
Hi jeff,
I got connectors.Thank you soooo much.
Grid Info Com
1. Go to C:\Program Files (x86)\OpenSpan\OpenSpan Plug-in for Microsoft Visual Studio 2015\Office2016
2. Copy all the dll''s within Office2016 and past it outside the "Office2016" folder
3. Right click on the Toolbox and select Choose Items. This will bring up a dialog to add the connector to the Toolbox.
