Summarize columns in Reports and Dat aPages
I have craeted a report "R" for the class "X" that makes a sum of two properties using the function SUM. This sum is expressed in a nuw column called "WorkSum".
I have defined also a Data Page "DP" of type List and Object Type "X" based on the report "R". I have used also a Data Transform "DT" for mapping the response of the report "R" and the class "X. In the "DT" definition I'm not able to get the column "WorkSum".
Any suggestion?
V.
***Updated by Moderator: Marissa. Removed user added #helpme group tag. Apologies for confusion, shouldn't have been an end-user option; updated categories***
