Murex
LB
Last activity: 23 Jan 2017 9:33 EST
Tracing the method Queue-For-Agent
I would like to know if we can trace the activity called by the agent.
For more information about my requirement:
I have a service rest that saves information in Pega. Upon failure, I call the method Queue-For-Agent (in order to queue all the requests that failed and then relanch the save later on).
For the Agent, I have linked it to an activity testOHLS:
When I run the activity of the service REST and simulate a failure, I can see in the tracer that the method Queue-For-Agent is called but I do not see the activity related to the agent (testOHLS) being called in the tracer. Is there a way to make sure that the Agent is calling the required activity ?
Thank you in advance for your help,
Mariane
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689978000/50bb9fe0-cd64-4752-92d7-d25f07efed16.jpg?itok=9G0tA9u5)
Incessant Technologies
Hi mariane,
Please find my attachment for steps to follow while tracing the agent.
ThankYou,
Srijith.
To trace the agent activity,you need to open System Management Application(SMA) and then need to select your agent and delay it.when the agent is delayed ,you need to select your requestor session from the requestor menu and then click on trace button within SMA.This will trace the agent activity.
Murex
LB
Thank you Srijith :)
I have opened the SMA, I can see my Agent runnable but the activity linke dto it is generating the below exception:
Please note that my activity is pretty straightforward (obj-open - given a hard coded value - propety set then save and commit)
Any idea what is causing the below error ?
Agent CSFW #0: MX-FW-CSFW-Work-Case.testOHLS encountered an execution error. Restarting after delay. Exception at 20161005T163938.275 GMT: com.pega.pegarules.pub.clipboard.ReadOnlyException: ReadOnlyPageOrProperty Param PageDirectoryImpl.getPage reserved page named 'Param' does not exist and cannot be created at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.getPage(AbstractPageDirectory.java:1107) at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.getDirectPage(AbstractPageDirectory.java:731) at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDirectPage(ThreadPageDir.java:471) at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:429) at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:421) at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getPage(PRThreadImpl.java:539) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2169) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2113) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.resolveEmbeddedPages(PropertyReferenceImpl.java:1789) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.resolveEmbeddedPages(PropertyReferenceImpl.java:1722) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGetString(PropertyReferenceImpl.java:1476) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getStringIfPresent(PropertyReferenceImpl.java:1258) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getStringIfPresent(PropertyReferenceImpl.java:1243) at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getStringIfPresent(PropertyReferenceImpl.java:1232) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.setupParameters(QueueProcessor.java:706) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:327) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:967) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1266) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1015) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:908) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:684) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Unknown Source)
Thank you :)
Murex
LB
Can you please provide more information about how to acccess the tracer ?
This is my SMA screen:
Thank you very much !
Mariane
Murex
LB
Reattaching the screenshot that is clearer
Hi mariane,
ThankYou,
Srijith.
Murex
LB
Mariane
Murex
LB
Hello Srijith,
I am trying to trace the activity called by the agent as specifed by your steps.
When clicikng on the 'Tracer' under the Requestor Management, the tracer is not launched, instead a Fail status popup appears as you can see in the below screenshot.
Altough a message 'TracerURL opeartion has been executed successfully' is displayed in the Requestor Management screen
Any ideas if there are some missing configurations that I need to set ?
Thank you,
Mariane
Hello Mariane,
Can you try remote trace option from designer studio tracer with that requestor ID and share the result?
Accenture Services
Hello Mariane,
As you are queueing the Agent using the "Queue-For-Agent" method, you can Keep the mode of the Agent as Advanced. Also,does your requirement need AQM? Probably not, as it will get executed, based on a precondition.
Try this configuration. Hope it works. Please let me know your feedback after trying this.
Jyotirmoy
Murex
LB
Hello Jyotirmoy and Harsha,
Thank you for your replies.
I noticed that the tracer only works on IE and not on Chrome. So I have been using IE to trace the agents sucessfully.
Thank you,
Mariane
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689998000/2ce7858e-be9a-4ce9-952c-745c52e7680e.jpg?itok=Bxtbc24w)
COFORGE
If you use chrome, the approach what Harsha has mentioned would work.
