Maantic Inc
Maantic Inc
Maantic Inc
Posted: Sep 26, 2016
Last activity: Sep 27, 2016
Last activity: 27 Sep 2016 2:51 EDT
Having same table in two different schemas, by passing same set of input parameter need to pull data from these tables. is it possible in report definition.
Exmaple : table A schema - test 1
name age place
John 21 MD
Paul 22 CT
Table 2 schema test 2
Name age Place
Jack 20 NY
Josh 25 NJ
Result
John 21 MD
Paul 22 CT
Jack 20 NY
Josh 25 NJ
Hi ,
I dont think, with report definition , we can fetch results from tables in 2 different schemas unless you are a super user , since the query similar to below gets fired : where dbo is the schema name .
SELECT "PC0".pyID AS "pyID" , "PC0".pzInsKey AS "pzInsKey" FROM dbo.pc_Sae_sample_Work "PC0" WHERE "PC0".pxObjClass = ?
Probably, you must be a super user, who has access to both the schemas (test1 and test2), and in the Sub-reports section, you need to provide a classname that is present in the other schema i.e test2 .
Haritha.D
