virtusa
Last activity: 12 Oct 2016 13:32 EDT
Defer load activity is not getting called from a Dynamic Layout in Pega 7.2
I'm trying to run preactivity to load data and display them in a section upon expand the header of a dynamic layout.
Below are the sample screens of how I configured the dynamic layout,
But the preactivity is not fired and displaying below error on the screen,
Kindly suggest is there any approach or known fix for this.
Thanks in Advance.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
Upon reviewing the associated SR, SA-28614 was issued as a resolution. Please review this SA if you have the same question.
I tried the same at my end and I see that it works fine.
Do you see the issue without the preload activity? If no, then one of the steps in the activity may be causing the issue.
Gisela
virtusa
Hi Gisela,
Yes preload activity is working, executed it by manually and checked. Also I tried with test activities and those are not getting called.
Thanks.
virtusa
It's seems like a installation or environment problem. Scenario is working fine with personal edition/local host. Will raise a SR. Thanks for the quick responses.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Hi Prasith,
Please let us know the SR number here if you create one with GCS. We will tag it to this post to track it until resolution!
Lochan | Community Moderator | Pegasystems Inc.
virtusa
Hi Lochan,
Raised SR-A98856.
Thanks.
Thanks Prasith!
I have tagged the number to your post above under the Related Support Case number field.
Venkat k
