Converting Number Field to Text
Hi I want to Convert value entered in a integer field to String after i click away from the integer field. How do i do this?
Hi
First you have to configure an activity to convert to string.
Then call that activity on change of the field. Configure like OnChange-RefreshSection-Call Activity
On property in actions tab add Action Set onchange, event Run DataTransform.
In Data Transform set value to String Property(PRPC do conversion automatically.....you don't need to do it explicitly.).
