JP Morgan Chase
Last activity: 8 Jul 2016 8:51 EDT
Data Page as source of Texbox in Section
Hi All, We have got a property defined in one of the work-classes. This property basically contains a code ;each code has a corresponding description which is available in a data page. In the UI (Section) we need to show this description instead of code. As of now the logic we have used is as below 1.Create a property of type "Single Page" which is based on the Data page class 2.Data Access --> Copy from data page. 3.The code property is passed as the input parameter to this Data Page. 4.In the UI Section we have defined a text box which is populated from this Single Page Property.desc. To me this approach seems to be bit convoluted ;isn't there a better and easy way to retrieve the description correspond to a key(in our case code). Our team is new to PEGA so still in learning phase...:) Thanks, George
***Updated by moderator: Lochan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option.
