How do i visually interpret Java heap memory utilization and Requestor count for my PRPC node over a period of time?
Hi Ankur,
Here are the steps that i would use,
- Run the command below to generate a text file containing space separated columns (time, total heap, used heap, requestor count),
$ grep 'Free memory' PegaRULES.log.2014-12-17 | awk '{print $1"-"$2, $22, $25, $28}' > temp.log
2. Open the newly created file from step above using Excel. Use space (‘ ‘) as a delimiter.
3. Insert a new row in the first row to include the title of each column. For example, time, total heap, used heap and requestor count.
4. In order to plot a chart, you can highlight all the columns and then try inserting a 2D line chart. A chart like below should be created,
5. In order to plot the requestor count on the second y-axis, double click on the requestor count line, and the following popup should appear.
Hi Ankur,
6. Choose ‘Secondary Axis’ and click Close. You can now see the requestor count against the second y-axis.
Hope this helps.
=waikei
Thanks Wai-Kei. This helps.
Hi Waikei,
Have tried this yesterday, Really Awesome ! just in 2 minutes - able to generate the Memory Utilization over Requestor Count of our application. Thanks for sharing.
Hari Kumar Alampuru
Is there a Windows equivalent to this option? It looks like a great utility to have for any environment.
Steve
Hi Steve,
I used cygwin in Windows. But i quickly tried out the below and it seems to work.
for /f "tokens=1,2,22,25,28" %i in ('findstr "Free memory" <name of the PegaRULES.log>') do @echo %i-%j %k %l %m
=waikei
Steve,
VisualVM and Cygwin are listed in the PDN Article, https://collaborate.pega.com/question/pega-marketing-marketing721vm20160509-broken, cited at the top of What are your favorite, free third-party tools?
Consider adding your new favorite freebies to the discussion, What are your favorite, free third-party tools?.
Thanks!
-Mary
Salutations,
If you want a PR_PERF_STATS view of requestor counts along with a good view of a lot of important data, run this query... Easy to make pretty graphs and dig into the data... Second query gives you the details...
Best Regards,
Dean
SELECT TO_CHAR(PXSNAPSHOTTIME,'MM/DD/YYYY-HH24') as "Time",
sum(pxinteractions) as "interactions",
sum(pxtotalreqtime) as "SumTotalReqTime",
sum(pxtotalreqtime) / sum(pxinteractions) as "AvgTotReqTime" ,
max(pxtotalreqtime) as "MaxTotReqTime",
sum(PXCONNECTELAPSED) as "SumConnectElap",
sum(PXCONNECTELAPSED) / sum(pxinteractions) as "AvgConnectElap",
max(PXCONNECTELAPSED) as "MaxConnectElap",
sum(PXOTHERIOCPU) as "SumPXOTHERIOCPU",
sum(PXOTHERIOCPU) / sum(pxinteractions) as "AvgOtherIO",
max(PXOTHERIOCPU) as "MaxOtherIO",
sum(PXJAVAASSEMBLECPU) as "SumJavaAsmCPU",
sum(PXJAVAASSEMBLECPU) / sum(pxinteractions) as "AvgJavaAsmCPU",
max(PXJAVAASSEMBLECPU) as "MaxJavaASMCPU",
sum(PXJAVAASSEMBLEELAPSED) as "SumJavaAsmElapsed",
sum(PXJAVAASSEMBLEELAPSED) / sum(pxinteractions) as "AvgJavaAsmElapsed",
max(PXJAVAASSEMBLEELAPSED) as "MaxJavaASMTime",
sum(PXCOMMITELAPSED) as "SumCommitElapsed",
max(PXCOMMITELAPSED) as "MaxCommitElapsed",
sum(PXDBOUTPUTBYTES) as "SumDBOutBytes",
sum(PXDBINPUTBYTES) as "SumDBInBytes",
sum(PXACTIVITYCOUNT) as "SumActivityCount",
sum(PXALERTCOUNT) as "SumAlertCount",
Salutations,
Best Regards,
Dean
sum(PXCOMMITCOUNT) as "SumCommitCount",
sum(PXCOMMITROWCOUNT) as "SumCommitRowCount",
sum(PXCONNECTCOUNT) as "SumConnectCount",
sum(PXRULECOUNT) as "SumRuleCount",
sum(PXRULEFROMCACHECOUNT) as "RuleFromCacheCount",
sum(PXRULESEXECUTED) as "RulesExecuted",
sum(PXRULESUSED) as "RulesUsed",
sum(PXOUTPUTBYTES) / sum(pxinteractions) as "AvgOutputBytes",
sum(PXOUTPUTBYTES) as "SumOutputBytes",
max(PXOUTPUTBYTES) as "MaxOutputBytes",
COUNT(DISTINCT(PXREQUESTORID)) as "Requestors",
COUNT(DISTINCT(PYUSERIDENTIFIER)) AS "USERS",
sum(PXDBINPUTBYTES) * 1.0 / sum(PXDBOUTPUTBYTES) as "DBRatio"
from pr_perf_stats
GROUP BY TO_CHAR(PXSNAPSHOTTIME,'MM/DD/YYYY-HH24')
order by TO_CHAR(PXSNAPSHOTTIME,'MM/DD/YYYY-HH24');
SELECT
PYUSERIDENTIFIER as "User",
PXREQUESTORID as "PXREQUSTORID",
sum(PXRULESEXECUTED) as "Rules Executed",
sum(PXRULESUSED) as "Rules Used",
from pr_perf_stats
GROUP BY TO_CHAR(PXSNAPSHOTTIME,'MM/DD/YYYY-HH24'),PYUSERIDENTIFIER,PXREQUESTORID
order by TO_CHAR(PXSNAPSHOTTIME,'MM/DD/YYYY-HH24'),PYUSERIDENTIFIER,PXREQUESTORID ;
