We have a issue in Report Definition when we have given a Summary View along with a Graph chart.
The results depicted in the chart are not in sync with the Summary View
Hfix-24833 resolves the issue with discrepancy in the dates in graph and RD.
We have raised this with our Product Specialist and they are working on this.
Jeena
Hello Bhashyam,
I am not sure if you are aware of the SR-A10501: Chart displays items with dates not included in filter, which I am working with one of your colleague.
Here are the two changes I have provided, could you please try this out and let me know if this works:
1. In the criteria section for the property ComplititionDate you need to change it from Date-Calendar to Datetime-Calendar, this will give correct Data.
2. And the Operator needs to have same timezone as Database timezone, this will resolved the issue with Date: for example id the DB is in IST, you can changed timezone for Operator as below.
