Need help with Punch Out UI
I need some help in implementing a punch out UI feature. By punch Out UI I mean that an entire UI layout present in an external system/application has to be presented on the portal. This will be achieved when I click on a Tab. Is this feasible in PEGA?
Hi ,
Is it like you want to show the entire site ( for example https://collaborate.pega.com/ ) as part of a tab inside your portal which is built on top of PEGA ?
If that is the case then you can configure your tab with an onClick -Open URL in Window function which can pass the URL as parameter
