Accenture
Last activity: 23 Dec 2015 9:12 EST
save as button not visible on certain map value
save as button private check out and action button not visible on certain map value
is there any hotfix or solution for this
Hi Rasaiya,
Can you share the screen shot of your issue and the PRPC version on which you are currently facing this issue.
![](/themes/custom/pegacc_theme/images/user-icon.png)
If you are accessing 6.2 in ie 11, you might see issues as it's not the supported ie version. See this https://community.pega.com/support/support-articles/save-button-not-visible-rules-when-launching-prpc-62-ie11
Updated: 19 Dec 2015 19:45 EST
Accenture
it is pega 7 1 7 and I m using ie11
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689966000/18c433f8-1e18-4340-81ce-2be99ef4528f.jpg?itok=rBmW0AVs)
JPMC
Hi Rasaiya,
A quick workaround for this could be private checkout that rule through the activity called pzprivatecheckout by passing the pzInsKey of the rule which you want to checkout.
Accenture
Ashish Agrawal That helps in private checkout.
Is there something for Save as also, I guess I heard something about WBSaveAs, but never used them.
Do we use the same activity for check out as well?
would it make sense to try disabling visible when conditions on these buttons for interim use or using non-ie browsers?
please refer: RULE-HTML-SECTION @BASECLASS PZRULEFORMTOOLBAR
Accenture
u mean to say private checkout the above rule and remove the visible when condition for such interim issue?
JPMC
Yes Rasaiya, you can try that as mentioned by Phani temporarily.
Also try saving by shortcut like ctrl+S
Also I would liek to know is that happenig for all map value rules? or any other rule types also face this issue? Is that very specific to just one rule or many such occurances in your system?
What is the behavior if you try to login by [email protected] and open any OOB map value?
Accenture
what is the password for the above user.
It is happening for few map value.
it's install
