Optus
Last activity: 26 Aug 2020 8:41 EDT
How to change the start date of Calendar?
Hi Team,
I have a requirement to change the start date of a calendar to Monday(When click on a calendar icon), a quick response much appreciated.
Thanks in advance.
Satish
The first day of week depends on the user country (-Duser.country jvm argument )
The below report is executed from Pega designer studio. In this report the filter criteria is greater than “Previous Week” on a datetime filed.
Below are the SQL query generated for two different JVM settings.
Case 1: user country = GB, Monday is the first day of the week.
SMA --> Advanced --> Web Tier Runtime Environment.
Case2: country = US, Sunday is the first day of the week.
In the above report execution for country = GB the report fetches data from 18th December 2017 00:00:000 hours which is Monday and the first date of the week as per the jvm Locale settings.
For the second case i.e. country = US the report fetches data from 17th December 2017 00:00:000 hours which is Sunday and the first date of the week as per the jvm Locale settings.
The user country must be set to enforce locale from the JVM level so that Java Calendar methods work accordingly.
The JVM argument is –Duser.country=XX. (XX = IN, GB, TR, US, etc)
The language JVM argument is –Duser.language=ll (ll = tr, fr, en, etc).
Hi
it depends on your operator locale .
When the locale is set something other than US ( en_US ) , Canada ( en_CA) and Japan ( ja_JP ) , the first day will be picked as Monday.
So if you have to change it, this is the quickest way !
Optus
Hi Santanu,
Thanks for reply. Based on locale we perform some time calculations, so it may affect these calculations. Is there any other way to change the start date of calender?
Hi
I checked the underlying code for calendar as well. com.pega.pegarules.pub.util.PRDateFormat.getFirstWeekDay() is responsible for this which in turn checkign the user locale.
So I dont think out of the box you can achieve this without changing your locale.
As alternative, you can opt for showing dates as drop downs. Or else, you can think of writing your own java script code to display your customized calendar .
Optus
Hi Santanu, thanks for the suggestion. I will try to customize the calendar functionality.
Adqura
Hi Santanu,
I tested what you suggested in this post but it doesn't seem to work in Pega 7.2 (java_1.7_64).
I created a simple report definition and picked "Previous week" in the filter condition. My locale is en_GB.
When I trace the SQL generated by RD above, it takes end of Saturday i.e. Sunday as the first day of the week.
Hi Santanu,
Previous Week in Report Definition
Database Name   	InteractionHistory
SQL   				SELECT "PC0".PXFACTID 		AS "pxFactID"
						 , "PC0".PXOUTCOMETIME 	AS "pxOutcomeTime"
					FROM PMIH.PR_DATA_IH_FACT "PC0"
					WHERE ( "PC0".PXOUTCOMETIME > ? )
SQL Inserts   		<2017-12-09 23:59:59.999>
Connection ID   	16
High Level Op ID   	9823
High Level Op   	list using a list spec
Object Class   		Data-Decision-IH-Fact
SQL insert value is December 9th, which is (end of) Saturday. I want it to be end of Sunday.
Is there any other parameter that has precedence over operator locale?
