American Express
Last activity: 9 Jun 2020 20:02 EDT
JDBC Isolation Level
Does the Transaction Commit Level include a switch for Read Uncommitted transaction? If not, we would like to understand in further detail how to introduce such a change into our implementation of the system
You can turn on jcc trace on jdbc connection to determine what level of isolation is in use although I believe it should be 'read committed' as is true for PRPC across the board.
IBM Collecting Data: Tracing with the IBM Data Server driver for JDBC and SQLJ - United States
American Express
Thank you Vipin. I did that. However, now I don't see any explicit calls to setTransactionIsolation method and now I have to believe based on that.... Pega is using the Default Isolation Level. (read committed) Given that information is now confirmed. How do I go about submitting an enhancement request to Pega Engineering so that I can have some sort of configuration based option in the production. Since it is something which must invoke SetTransactionIsolation in the proprietary Java Code maintained by Pega
American Express
Meant to say" I need a configuration option somewhere in the product" otherwise I cannot control this level of setting myself
I need to engage Pega engineering for an enhancement request to BIX
You can enter an SR with GCS to get the Enhancement Request entered but it is advised to contact your AE once you have the ID to weigh in on the request.
Pegasystems
Hi Robert,
Typically users don't use the "Run" button on the Rule-Admin-Extract ruleform to run extracts. This button underneath uses the executeExtract API. They use the command line version of BIX. You can refer to this in the BIX User Guide - https://docs-previous.pega.com/bix-71-user-guide (This requires the setup of its own data source in prconfig.xml file)
That said, we do not change the isolation level that we get from the connection pool for this API.
-Rajiv
American Express
Hi Rajiv, that was my point. I need to be able to change the connection setting but I cannot because it is inside a Private API that only Pega internal code has access to and is not configurable anywhere else, like in an App Container such as Websphere. I am implementing Pega BIX as was prescribed through direct invocation from command prompt / shell script.
This is an enhancement request then?
this is most likely the case, Please have your account executive contact Pega product management for the enhancement request.
I can actually take care of the enhancement request here Kevin Zheng, no need to open an SR. I'll update the thread when I have the enhancement request number. Robert Seplin I may reach out to you via private message for additional information if necessary.
Thanks everyone!
Pegasystems
Hi Robert Seplin ,
So for the command line BIX, would it be possible for you to set up your own connection pool with the required isolation level rather than using the executeExtract API? As I mentioned, executeExtract is not the preferred way as extracts can be resource intensive depending on the size and format of the extract and therefore it is best done via the command line option provided.
-Rajiv
American Express
Connection pool, perhaps, only if I set the BIX extract up in such a way that it executes in some kind of application container, and not just from the Shell
Robert Seplin
WSP (World Service Portal)
