Murex
LB
Last activity: 2 Feb 2016 10:24 EST
Select All Checkbox Remains Selected
We are facing a problem with a checkbox in a repeating grid. When I launch a new case, the first step contains a repeating grid with a Select All checkbox (see attachment ConfigureRows). If I select this "Select All" checkbox and click next, I get transported to the next screen which has the same functionality as the first. The problem is that upon entering that second stage, the "Select All" checkbox is already marked as true (see attachment ConfigureColumns) without us taking any action to select it.
I have tried to look for a way to reset that checkbox so that it defaults to be un-selected but I have been unsuccessful in doing so.
Any suggestions in regards to this matter?
Thank you for your help!
Message was edited by: Vidyaranjan Av Included Category
Hi
You can think of using "pySelected" property against the checkbox which you are using for the option Select All / Deselect all.
Post that you can think of using a way to deselect the same when you are clicking next or when a new screen is loaded.
You may also check a post on this community :
