LANIT JSC
RU
Last activity: 7 Apr 2017 23:40 EDT
System not able to find Function in one of the environments (com.pega.pegarules.pub.generator.UnresolvedAssemblyError , InvalidExpression, No candidates found)
On production system (PRPC 7.1.8) we have some problem:
"com.pega.pegarules.pub.PRAppRuntimeException: The flow SendToCreditDepartment had a problem on step Integrator2 of: com.pega.pegarules.pub.generator.UnresolvedAssemblyError: ** 2001449583§EscapeSpecSymbols§PegaEL-InvalidExpression No candidates found [possible function name, ruleset/version or number of parameter problem] for Rule-Utility-Function in ruleset list <null> expected since isEditing is false ruleset = ECM-FileNetComponent library = FileNetComponent functionName = EscapeSpecSymbols parameters = [ Item: param.PackageName Pega type = text Java data type = String] @(ECM-FileNetComponent:FileNetComponent).EscapeSpecSymbols(param.PackageName)
The error was cleared by performing a Revalidate and Save of the rule where the function was referenced.
Also, we were given an official response from Pegasystems, this is a bug in the engine, and they gave us a hotfix (HFix-25979) that we do not encounter this problem in the future.
This problem occurs accidentally and is uncertain.
Related links to this problem:
- https://community.pega.com/support/support-articles/unable-find-function-after-upgrade-pega-718
- https://pdn.pega.com/forums/system-operations/system-not-able-find-function-one-environments
Met you are such a problem? What helped you solve it?
