Cooper Consulting
Last activity: 10 Apr 2017 9:28 EDT
Microsoft word merge not working with pega 7.1.8.
As you can see in the below code my logic is using i see my logic is using sWordManagerLaunchExternal which is in the prVisioInterface library.
In pega 7.1.8 the prVisioInterface library is blocked.
Are there any alternate methods to do the word merge.
<script for="window" event="onload">
alert('1');
SetupSettingsXML();
</script>
<script for="window" event="onbeforeunload">
try
/* Abhilash :check for closing of section before 10 seconds while downloading components for calls to avoid "line 0" error */
if( iCntr < 200 && iWaitRenav != 0){
clearTimeout( iWaitRenav);
if( bEditInProgress)
return "Word editing is in progress!\n*** Unsaved changes will be lost ***\nPress 'Cancel' to leave flowaction open.";
catch (e)
</script>
<script for="window" event="onunload">
try
ClearWordActiveX( );
alert('1');
SetupSettingsXML();
</script>
try
catch (e)
</script>
try
catch (e)
</script>
<script for="WordActiveX" event="EditDocEvent( sEventCode, sEventData)">
if( sEventCode == "EditDocInitOK")
if( iWaitFailedLaunch != 0)
try
clearTimeout( iWaitFailedLaunch);
iWaitFailedLaunch = 0;
bEditInProgress = true;
ResetLaunchButton( true, "Editing in progress ...");
// alert( "The document is done loading" );
catch (e)
alert(" Error in WordActiveX event handler: " + e.description);
else if( sEventCode == "EditDocClosed")
try
{ bEditInProgress = false;
/* added by Abhilash */
try { top.window.focus(); } catch(e) {}
var oTextArea = document.all( "TextToEdit");
oTextArea.value = document.all( "WordActiveX").sGetEncodedBinaryFile( sEditedDocPath);
oSettingsXML.selectSingleNode("//pySkipExternalInit").text = "true";
setTimeout('RenavigateWordActiveX( "")', 20);
catch (e)
setTimeout('ResetLaunchButton( false, "Edit Document", true)', 200);
</script>
<script>
var iWaitFailedLaunch = 0;
var bEditInProgress = false;
var sEditedDocPath = "";
var iCntr=0;
var sMsg="";
var iWaitRenav=0;
var iWaitDoExtLaunch=0;
function HandleFailedLaunch()
try
alert( "There was a problem launching PRPC Word Editor.");
catch (e)
alert("Error in HandleFailedLaunch: " + e.description);
ResetLaunchButton( false, "Edit Document", true);
// Get URL encryption information.
function getURLencryptToken() {
try {
var sEncryptToken = "";
if(typeof bEncryptURLs != "undefined" && bEncryptURLs) {
sEncryptToken = getCookie();
return sEncryptToken;
catch(e) { return ""; }
function DoLaunchExtWord()
try
alert('11');
var oWordActiveX = ConstructWordActiveX( );
alert(oWordActiveX);
if( oWordActiveX == null)
{alert('12');
return;}
alert('13');
oSettingsXML.selectSingleNode("//pyEditedPath").text = sEditedDocPath;
alert(sEditedDocPath);
alert('14');
/* Get URL encryption key and pass to ActiveX, which will transfer it to the Word VBA */
var sEncryptToken = getURLencryptToken();
alert(sEncryptToken);
if(sEncryptToken != "") {
alert('18')
oSettingsXML.selectSingleNode("//pyEncryptToken").text = sEncryptToken;
oSettingsXML.selectSingleNode("//pyEncryptEnable").text = "true";
/* Launch external Word session. Process external launch return code. */
alert('19');
alert(oTextArea);
var sTemplateName = document.all("TemplateName").value;
alert(sTemplateName);
alert('20');
var sRetVal = oWordActiveX.sWordManagerLaunchExternal( WordEditDiv, oSettingsXML, sTemplateName, oTextArea.value);
alert(sRetVal) ;
if( sRetVal == "ERROR")
alert('21') ;
ResetLaunchButton( false, "Edit Document");
else
alert('22');
iWaitFailedLaunch = setTimeout('HandleFailedLaunch()', 15000);
sEditedDocPath = sRetVal;
if( iWaitDoExtLaunch != 0)
clearTimeout(iWaitDoExtLaunch);
iWaitDoExtLaunch = 0;
catch (e)
if( e.number==-2146827850){
/* Abhilash :loop till 10 seconds elapsed for RenavigateWordOCX() API for downloading component. sMsg will be null till 10 seconds. */
if( sMsg == "")
iWaitDoExtLaunch=setTimeout('DoLaunchExtWord()', 600);
else
ResetLaunchButtons( false, "Edit");
alert("Error in DoLaunchExtWord: " + e.description);
/* Launch exernal Word session. */
function LaunchExtWord()
try
alert('6');
RenavigateWordActiveX( "BeingEditedMsg");
alert('7');
setTimeout('ResetLaunchButton( true, "Launching Word")', 20);
alert('8');
ResetLaunchButton( true, "Launching Word. Please wait...");
alert('9');
setTimeout('DoLaunchExtWord()', 400);
alert('10');
catch (e)
alert("Error in LaunchExtWord: " + e.description);
/* Dynamically construct Word ActiveX object */
function ConstructWordActiveX( )
try
alert('15');
var oWordActiveXDiv = document.all( "WordEmDiv");
alert(oWordActiveXDiv);
var oWordActiveX = oWordActiveXDiv.all( "WordActiveX");
if( oWordActiveX)
{alert('16');
return oWordActiveX;}
alert('17') ;
/* Calculate textarea extent in twips. */
var extX = oTextArea.offsetWidth * 26.5;
var extY = oTextArea.offsetHeight * 26.5;
/* Recreate Word ActiveX object. */
oWordActiveXDiv.innerHTML = '<div id=oOcxDiv style="position:absolute; visibility:visible;">' +
'<object classid="clsid:BE8EEE38-A7C5-4674-A6C4-C2D7421FDD10" ' +
' codebase="prvisiointerface.cab#version=5,4,0,20"id=WordActiveX>' +
'<param name="_ExtentX" value="' + extX + '">' +
'<param name="_ExtentY" value="' + extY + '">' +
'<span id="VisioInterfaceFail" style="color:red">PegaRULES Office Interface Control Load Failure!</span>' +
'</object></div>';
return oWordActiveXDiv.all( "WordActiveX");
catch (e)
alert("Error in ConstructWordActiveX: " + e.description);
return null;
/* Navigate to fixed document ActiveX. */
function RenavigateWordActiveX( sFile)
try
var oWordActiveX = document.all( "WordActiveX");
iCntr++;
if( oWordActiveX != null)
oWordActiveX.bRenavigateBrowserControl( sFile);
sMsg="";
/* making counter zero if all well. */
iCntr=0;
if( iWaitRenav != 0)
clearTimeout(iWaitRenav);
iWaitRenav =0;
catch(e)
/* added by Abhilash . Error number corresponds "Object Doesnot Support this Property or Method" */
/* usually this happens when API Not found in Component or Conponent is not loaded yet. */
/* Abhilash : checking for 10 seconds. ( 50ms * 200 = 10000ms i.e 1s.) */
if( iCntr>200)
sMsg="failed to load prVisioInterface control";
alert(sMsg);
else
iWaitRenav=setTimeout('RenavigateWordOCX()', 50);
else
alert("Error in RenavigateWordOCX: " + e.description);
/* Navigate to blank and unload ActiveX. */
function ClearWordActiveX( )
try
var oOcxDiv = document.all( "WordEmDiv");
var oWordActiveX = oOcxDiv.all( "WordActiveX");
oWordActiveX.bRenavigateBrowserControl( "");
oOcxDiv.parentElement.removeChild( oOcxDiv);
catch(e)
alert("Error in ClearWordActiveX: " + e.description);
/* Setup Settings XML. */
function SetupSettingsXML()
try
alert('2') ;
oSettingsXML.selectSingleNode("//pySiteMinderCookie").text =
sGetCookie( oSettingsXML.selectSingleNode("//pySiteMinderHeader").text);
alert( oSettingsXML.selectSingleNode("//pySiteMinderHeader").text);
alert('3');
catch(e)
alert("Error in SetupSettingsXML: " + e.description);
/* Disable/Enable external edit launch buttons. */
function ResetLaunchButton( bDisable, sCaption, bHide)
try
var oButton = null;
oButton = document.all("LaunchExtSession");
oButton.disabled = bDisable;
oButton.value = sCaption;
if ( bHide )
oButton.style.display = "none";
catch (e)
alert(" Error in ResetLaunchButton: " + e.description);
function sGetCookie ( sCookieName) {
var results = document.cookie.match ( sCookieName + '=(.*?)(;|$)' );
if ( results )
return ( unescape ( results[1] ) );
else
return "";
</script>
<script>
function launchTemplate ( )
alert('4');
var templateName = document.getElementById( "TemplateName" ).value;
alert(templateName);
LaunchExtWord( templateName );
alert('5');
</script>
<style>
.wordIcon
{ background-image: url("webwb/microsoft_word_icon.png");
background-position: 0px 0px;
background-repeat: no-repeat;
width: 16px;
height: 16px;
.hideWordIcon
{ background-image: none;
</style>
<table width="100%" cellspacing="0" cellpadding="2" border="0">
<tr><td colspan="2" style="height: 10px;"><input id="TemplateName" type="hidden" value='<%= tools.getParamValue("TemplateName") %>'>
</td></tr>
<tr><td> </td><td style="height: 22px;">
<style>
.wordIcon
width: 16px;
height: 16px;
.buttonUnderLine
{ text-decoration: underline;
</style>
<BUTTON title='Click to create <%= tools.getParamValue("TemplateName") %>' id="LaunchExtSession" name="LaunchExtSession" onclick="launchTemplate();">
<SPAN style="vertical-align:middle" class="wordIcon"> </SPAN>
<span style="vertical-align:middle" class="buttonText" onmouseover="this.className='buttonUnderLine'" onmouseout="this.className='buttonText'"><b><font color=blue size=2>Create Document</font></b></span>
</BUTTON>
</td></tr>
</table>
<xml id=oSettingsXML>
<?xml version="1.0"?>
<pega:include type="Rule-Obj-XML" name="WordManager_Settings.Generic"/>
</xml>
