MBAFC
CN
Last activity: 22 Feb 2016 20:23 EST
SQL Problems
Is there somebody know why this happend?
2015-12-19 22:00:11,631 [ce Thread Pool -- 59] [ ] [ ] [ ] ( etier.impl.EngineStartup) WARN - PegaRULES shutdown initiated.
2015-12-19 22:00:11,684 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (internal.context.RuleUsageImpl) INFO - Starting RuleUsage snapshot: recent
2015-12-19 22:00:27,714 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (internal.context.RuleUsageImpl) INFO - RuleUsage snapshot completed: recent (committed 727 usage instances and 3119 detail instances)
2015-12-19 22:00:27,715 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (internal.context.RuleUsageImpl) INFO - Starting RuleUsage snapshot: shutdown
2015-12-19 22:00:33,234 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (internal.context.RuleUsageImpl) INFO - RuleUsage snapshot completed: shutdown (committed 727 usage instances and 0 detail instances)
2015-12-19 22:00:33,278 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] ( search.internal.RuleIndexer) WARN - Received request to interrupt indexing.
2015-12-19 22:00:33,284 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (nal.async.AsyncServicesManager) INFO - Shutting down AsyncServicesManager.
2015-12-19 22:00:33,284 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] ( pega.TRACE.adp_lifecycle) INFO - Shutting down AsyncServicesManager.
2015-12-19 22:00:33,284 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (al.async.AsyncServicesExecutor) INFO - Shutting down, declarative load threadpool
2015-12-19 22:00:33,288 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Connection to pegarules left at shutdown
2015-12-19 22:00:33,289 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Connection to pegadata left at shutdown
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2015-12-19 22:00:33,293 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: GLPD
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2015-12-19 22:00:33,294 [ce Thread Pool -- 59] [ STANDARD] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: GLPR
2015-12-19 22:00:33,300 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR - There was a problem with the database when getting a list:
2015-12-19 22:00:33,300 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR - There was a problem with the database when getting a list: com.pega.pegarules.pub.database.ConnectionException: There was a problem processing the results of a database list: code: 0 SQLState: Message: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac From: (BB1BD5B3D73DF93B934807843112A26FA) SQL: select pzPVStream from GLPD.pr_assign where pyAssignmentStatus = ? and (pxUpdateDateTime Caused by SQL Problems. Problem #1, SQLState null, Error code 0: java.sql.SQLException: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:163) at com.pega.pegarules.data.internal.access.PageResultPackager.packageResults(PageResultPackager.java:363) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6224) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6022) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:5985) at com.pegarules.generated.activity.ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.step3_circum0(ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.java:382) at com.pegarules.generated.activity.ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.perform(ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.java:116) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3275) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10265) at com.pegarules.generated.activity.ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.step4_circum0(ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.java:349) at com.pegarules.generated.activity.ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.perform(ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.java:120) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3275) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:884) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1192) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:829) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:617) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Thread.java:745) Caused by: java.sql.SQLException: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac at org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.tryLock(BaseWrapperManagedConnection.java:408) at org.jboss.jca.adapters.jdbc.WrappedConnection.lock(WrappedConnection.java:147) at org.jboss.jca.adapters.jdbc.WrappedStatement.lock(WrappedStatement.java:114) at org.jboss.jca.adapters.jdbc.WrappedStatement.getResultSet(WrappedStatement.java:727) at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.getResultSetFromStatement(DatabasePreparedStatementImpl.java:1336) at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.getResultSet(DatabasePreparedStatementImpl.java:1348) at com.pega.pegarules.data.internal.access.PageResultPackager.packageResults(PageResultPackager.java:248) ... 20 more
| 2015-12-19 22:00:33,307 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:07.10] (ernal.async.BatchRequestorTask) ERROR - Batch activity "Assign-.AgentBulkProcessing" threw: com.pega.pegarules.pub.PRRuntimeError: There was a problem processing the results of a database list: code: 0 SQLState: <none> Message: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac at com.pegarules.generated.activity.ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.step3_circum0(ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.java:384) at com.pegarules.generated.activity.ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.perform(ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.java:116) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3275) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10265) at com.pegarules.generated.activity.ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.step4_circum0(ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.java:349) at com.pegarules.generated.activity.ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.perform(ra_action_agentbulkprocessing_7fa98f1baeaec24ce7482333b6a97816.java:120) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3275) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:884) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1192) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:829) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:617) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Thread.java:745) Caused by: com.pega.pegarules.pub.database.ConnectionException: There was a problem processing the results of a database list: code: 0 SQLState: <none> Message: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac From: (BB1BD5B3D73DF93B934807843112A26FA) SQL: select pzPVStream from GLPD.pr_assign where pyAssignmentStatus = ? and (pxUpdateDateTime <= ? or pxUpdateDateTime is null) and pxObjClass = ? order by pzInsKey SQL Inserts: <IN PROCESS> <20151219T175533.277 GMT> <Assign-Schedule-Future> Caused by SQL Problems. Problem #1, SQLState null, Error code 0: java.sql.SQLException: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:163) at com.pega.pegarules.data.internal.access.PageResultPackager.packageResults(PageResultPackager.java:363) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6224) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6022) at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:5985) at com.pegarules.generated.activity.ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.step3_circum0(ra_action_cleanupbulkprocessqueue_969a73e625d86cce5a006589f59f57ba.java:382) ... 16 more Caused by: java.sql.SQLException: Interrupted attempting lock: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7a104cac at org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.tryLock(BaseWrapperManagedConnection.java:408) at org.jboss.jca.adapters.jdbc.WrappedConnection.lock(WrappedConnection.java:147) at org.jboss.jca.adapters.jdbc.WrappedStatement.lock(WrappedStatement.java:114) at org.jboss.jca.adapters.jdbc.WrappedStatement.getResultSet(WrappedStatement.java:727) at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.getResultSetFromStatement(DatabasePreparedStatementImpl.java:1336) at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.getResultSet(DatabasePreparedStatementImpl.java:1348) at com.pega.pegarules.data.internal.access.PageResultPackager.packageResults(PageResultPackager.java:248) ... 20 more |
