Keep seeing deadlock on Log-RuleUsage-Details - why and what is the impact
Hi there,
In production logs, I keep seeing the error with the updating rules usage.... Can we do anything about this? e.g. Index needed? and what is the impact for the client?
Hi there,
2016-04-20 15:00:28,744 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR - Encountered problem when performing a Commit com.pega.pegarules.pub.database.DatabaseException: Database-General Problem saving instance of class Log-RuleUsage-Details 1205 40001 Transaction (Process ID 95) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction. From: (BD9BB6F9DA5D71D538416E9F46A42EA18) SQL: MERGE INTO dbo.pr4_log_rule_usage_details t USING (VALUES (? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ?)) AS inputs ("pzInsKey" , "pxAssemblyCacheKey" , "pxClassName" , "pxCreateDateTime" , "pxDetailIndex" , "pxInsName" , "pxObjClass" , "pxParentRuleUsageKey" , "pxSystemNode" , "pxUpdateDateTime" , "pxUseCount" , "pyLabel") ON (t.pzInsKey = inputs."pzInsKey") WHEN MATCHED THEN UPDATE SET pxAssemblyCacheKey = inputs."pxAssemblyCacheKey" , pxClassName = inputs."pxClassName" , pxCreateDateTime = inputs."pxCreateDateTime" , pxDetailIndex = inputs."pxDetailIndex" , pxInsName = inputs."pxInsName" , pxObjClass = inputs."pxObjClass" , pxParentRuleUsageKey = inputs."pxParentRuleUsageKey" , pxSystemNode = inputs."pxSystemNode" , pxUpdateDateTime = inputs."pxUpdateDateTime" , pxUseCount = inputs."pxUseCount" , pyLabel = inputs."pyLabel" , pxCommitDateTime = CURRENT_TIMESTAMP WHEN NOT MATCHED THEN INSERT (pzInsKey , pxCommitDateTime , pxAssemblyCacheKey , pxClassName , pxCreateDateTime , pxDetailIndex , pxInsName , pxObjClass , pxParentRuleUsageKey , pxSystemNode , pxUpdateDateTime , pxUseCount , pyLabel) VALUES (inputs."pzInsKey" , CURRENT_TIMESTAMP , inputs."pxAssemblyCacheKey" , inputs."pxClassName" , inputs."pxCreateDateTime" , inputs."pxDetailIndex" , inputs."pxInsName" , inputs."pxObjClass" , inputs."pxParentRuleUsageKey" , inputs."pxSystemNode" , inputs."pxUpdateDateTime" , inputs."pxUseCount" , inputs."pyLabel"); SQL Inserts: Caused by SQL Problems. Problem #1, SQLState 40001, Error code 1205: com.microsoft.sqlserver.jdbc.SQLServerException: Transaction (Process ID 95) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction. at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:257) at com.pega.pegarules.data.internal.access.Saver.addBatch(Saver.java:980) at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:796) at com.pega.pegarules.data.internal.access.Committer.performOps(Committer.java:236)
Regards
Seri
