How to disable SECU0001 alert in Pega 7.1.8?
Hi Pavan,
You will see SECU0001 when you have additional properties that weren't expected in your post data. Examine the SECU0001 alert to see if we can get rid of the extra properties to make this go away
If you want to ignore this you can also use the below prconfig setting
<env name="security/unexpectedinputpropertyalert" value="false" />
Hope this helps!
Thanks Harish. This really helps.!!
Harish we are not able to solve after changing that setting we are using 7.2 version of prpc can you suggest?
Hi Prasanth,
I think this setting is enabled default in PRPC 7.2 version. Whether you have analyzed why it is happening ?
https://docs-previous.pega.com/secu0001-alert-unexpected-properties-received-http-request
