Hi Aniket,
Search text box in filter searches the values in column having searched text
Search Text Uses .pySearchText present in pzGridFilterRangeFields Section
For example, if we search for Case ID's having -31
will filter all Case ID's which have -31
To select specific list of values, check boxes can be used.
If you are expecting range search, then that is possible only for columns with integer / Date / Date Time type.
My users want to enter multiple values in the text box to search multiple records.
Aniket,
Entering multiple values separated by a comma in the search textbox of the filter will not give the result you expect. Actually, with the current Pega design, you're supposed to enter only one value in the text box.
Even with customization we cannot achieve your requirement of using multiple values to filter Reports or Grids sourced with ReportDefinitions.
If using pagelist sourced Grids, then you can probably do custom filtering to achieve the above requirement.
