AA
Last activity: 4 Feb 2019 14:19 EST
Pega 7.1.9 on Java 8 - MaxMetaspaceSize??
Very strange that Pega didn't recommend anything about MaxMetaSpaceSize introduced in Java8, does anyone have an idea. I raised an SR to understand if its missing in the documentation but I was asked to raise a question here instead. I could only see a one liner highlighted in the red below mentioning that PermSize isn't required in Java8 but what about the MaxMetaSpaceSize? Any suggestions would be greatly appreciated.
https://pdn.pega.com/documents/pega-72-platform-installation-guide-jboss-and-oracle
Page 38:
Set the JVM memory parameters: Pegasystems recommends these settings:
- Initial Heap Size (Xms): between 4 GB - 8 GB, based on monitoring of memory usage and GC frequency
b. Maximum Heap Size (Xmx): between 4 GB - 8 GB or larger, depending on your system configuration. See Application server memory requirements for more information.
If your application server is using the recommended Oracle JVM, and you are using Java 7, also add the PermSize and MaxPermSize settings. (Java 8 does not require you to set PermSize.)
Page 38:
- PermSize (-XX:PermSize): 512 MB
- MaxPermSize (-XX:MaxPermSize): 1024 MB
Note: If the server does not have enough memory allocated to run the Pega 7 Platform, the system may hang without an error message. Your values may need to be higher than these
recommendations based on your server hardware, the number of other applications, and the number of users on the server.
Modify the JAVA_OPTS environment variable to update the JVM memory values, for example:
-Xms4096m –Xmx8192m –XX:PermSize=512m –XX:MaxPermSize=1024m
Your modified JAVA_OPTS setting should look similar to this:
JAVA_OPTS="-Xms4096m –Xmx8192m –XX:PermSize=512m –
XX:MaxPermSize=1024m"-Dsun.rmi.dgc.server.gcInterval=3600000
***Updated by Moderator: Marissa to add Doc Bug group tag***
