Bank of America Corporation
Posted: Jun 29, 2016
Last activity: Jan 23, 2017
Last activity: 23 Jan 2017 2:58 EST
ORA-01461: can bind a LONG value only for insert into a LONG column
SR-A77450
Detailed Description
Receive production alert from BIX:
11:55:03,501 [ia.bankofamerica.com] ( internal.access.ExtractImpl) ERROR - Batch Update Exception: ORA-01461: can bind a LONG value only for insert into a LONG column
java.sql.BatchUpdateException: ORA-01461: can bind a LONG value only for insert into a LONG column
Show More
SR-A77450
We ran into this issue before and determined some characters were from windows (smart quote) being embedded in the case history note. Now we run into this issue again and root cause is still unknown.
We'd like to request,
a. How to find the case causing this issue and what character in the blob is causing this issue. We can not look at a case in UI because data is truncated. We can't look from Developer UI because trying to look at just one case is throwing internal server error.
b. If there's a way to fix this data from the back-end (without user having to reopen the case and edit the data) that'd be awesome as well.
Steps to Reproduce
Rerun BIX
Error Message
java.sql.BatchUpdateException: ORA-01461: can bind a LONG value only for insert into a LONG column at oracle.jdbc.driver.OraclePreparedStatement.executeBatch(OraclePreparedStatement.java:10055)
at oracle.jdbc.driver.OracleStatementWrapper.executeBatch(OracleStatementWrapper.java:213)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.executeBatch(DatabasePreparedStatementImpl.java:532)
at com.pega.pegarules.data.internal.access.ExtractImpl.addDbRow(ExtractImpl.java:3866)
at com.pega.pegarules.data.internal.access.ExtractImpl.writeRow(ExtractImpl.java:3654)
at com.pega.pegarules.data.internal.access.ExtractImpl.WritetoOutput(ExtractImpl.java:3569)
at com.pega.pegarules.data.internal.access.ExtractImpl.doExtract(ExtractImpl.java:2478)
at com.pega.pegarules.data.internal.access.ExtractImpl.runExtract(ExtractImpl.java:1280)
at com.pega.pegarules.data.internal.access.ExtractImpl.run(ExtractImpl.java:1050)
at com.pega.pegarules.data.internal.access.ExtractImpl.init(ExtractImpl.java:1024)
at com.pega.pegarules.data.internal.access.ExtractImpl.main(ExtractImpl.java:976)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:348)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:389)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:438)
at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:88)
Show Less
