Murex
LB
Last activity: 5 Jul 2016 2:53 EDT
Change Inline style of a row on a when condition
I have a grid of names that takes from a report definition. I want the background color of the row to be red if the name is "Test" for example. the rest are normal. How to achieve that?
Hi Sidani, Good morning!
we could try the following applying the style applied either from skin or custom read-write css..
- inline css <pega:when name="IsFlagTrue">background-color: gray;</pega:when>
- have a section dropped in the repeat grid with TWO layouts
Please share your thoughts/observations, Thank you!
psahukaru
Murex
LB
thank you for your reply, but can you please explain more since I'm new to css in pega
Murex
LB
hi, I have .Active bool in my report definition where when it is 0 i display normally and if it is 1 i display with background red.
I did this on the row level:
<pega:when Active="IsFlagTrue">color: black; background-color: red; font-size: 14; font-style: other; </pega:when>
but nothing is happening is ther something I am missing?.
Thank you for your time!
Virtusa
Hi Bashir,
If i'm correct, Could you please replace "Active" with "name". Since the actual syntax is <pega:when name="WhenRule"></pega:when>.
Bala.
Murex
LB
I can make a when rule but I am unable to pass the parameters to it. any help would be so much appreciated!
- syntax: <pega:when name="<WHEN RULE NAME>">background-color: gray;</pega:when>
Murex
LB
i mean I cannot pass parameters to the when rule thasts why I want to use && and ||
