Sample Java class for Connect-SAPJCo
We have a requirement to implement Connect-SAPJCo where we need to write Java classes to hold methods corresponding to each BAPI function that needs to be called. Has anyone implemented a Connect-SAPJCo already ? If yes, can you suggest what exactly need to go in the Java code ? How do you handle the connection to SAP system destination (we are using SAP R/3) ? It will be of great help if anyone can share a code snippet. There are lot of code snippets available on internet but they mostly apply from a application server context and it's little bit confusing. Any help is greatly appreciated.
Thanks in advance..
