KAFKA Message listener in Pega
Hi ,
Did any one connected to Apache Kafka Messaging from Pega. If so please share your expirence and code snippet if any
***Updated by moderator: Lochan to add enhancement request ID***
Hi AjithA82
not sure about this.
I will forward your question to the relevant SME. They will get back to you.
Regards
DIMIS
Hi Dimis,
I also need an answer for this inquiry. Version we're going on is Proprietary information hidden -Details of my project are as follows;
Business requirement: As a Pega Marketing user, I would like to send a push notification to my customers, based on their geo-location.
Specification: Inhouse mobile application retrieves customer's geo-location at each login and this data is pushed to Kafka Queue.
Implementation: Listen Kafka Queue, and create an event based campaign on Pega Marketing.
Oğuz
I also need to integrate Kafka with PRPC. But what I do understood from Other thread that There is no built-in support for Apache Kafka in Pega 7. Only way to connect Kafka with pega will be connecting via Java Connector or need to import their JMS client libraries into Pega.
I believe if we raise a SR for that, Pegasystem can provide some hotfix to connect KAFKA with Pega.
I am not sure that is a correct understanding. Inherent support for Apache Kafka would be an enhancement to the product and would be added to a future release of the Pega platform. Please work with your account executive to push for this enhancement based on the criticality of this need in your application.
I know this type of problems won't be supported by Pega by a SR.. These Enhancements are very big if I consider it for Pegasystems. But They can give some other work around may be.
Right, and thus it would be, for now, a custom implementation that you would need to do yourself for your application (and possibly share in it in Pega Exchange?).
So I raised a SR (SR-B8456-Media Request Type) with Pegasystems for Connectivity of Pega.
So as expected the SR did not do any good . So lets hope we will have some method or Integration connector for KAFKA. in 7.2.2 onwards or later - Sooner the better, Fingers Crossed :)
***Moderator: Lochan edited message to remove SR communication***
I already created an enhancement request for Apache Kafka integration.
It is in the backlog.
Do you have a solution ???
Can you share the Tkt_No ???
Hi Ranabir,
The enhancement request number is displayed under the Related Support Case Number field in the original post above. Please refer this number to your Account Executive should you wish to actively follow up on this request.
Lochan | Community Moderator | Pegasystems Inc.
