Bank of America
Bank of America
Bank of America
Posted: Jan 7, 2016
Last activity: Jun 14, 2016
Last activity: 14 Jun 2016 5:58 EDT
PegaRules Process Commander 719 PE- Unable to connect to database
While installing the Pega7 personal edition, I am facing the following problem.
[echo] Waiting for Postgres to start...
[echo] Connected to Database.
[exec] ALTER ROLE
[exec] psql:C:/PRPCPersonalEdition/scripts/SetupDBandUser.sql:3: ERROR: database "pega" already exists
[exec] psql:C:/PRPCPersonalEdition/scripts/SetupDBandUser.sql:5: NOTICE: schema "personaledition" does not exist
[exec] ALTER ROLE
BUILD FAILED
C:\Users\XXX\Desktop\Pega\114898_PE719\pegaGuiInstallerTemp1\build.xml:182: Unable to connect to database within 15 seconds.
Total time: 1 minute 28 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
