Last activity: 24 Nov 2015 16:10 EST
question on rule resolution
Consider the following scenario:
The PIPFW application has the following application RuleSets:
- PIPFW:01-01
 - PIPFWInt:01-01
 - LES:01-01
 - LESCatalog:01-01-01
 - LESInt:01-01
A rule with an applies-to class of “ABC-FW-LoanReq-Work-Autoloan” calls “Rule123”.  There are 6 copies of Rule123 in the system, with the Applies To Class, RuleSet Version, and Availability, as follows:
- Option A: ABC-FW-LoanReq-Work, PIPFW:01-01-05, Availability = Withdrawn
 - Option B: ABC-FW-LoanReq-Work, PIPFW:01-01-03, Availability = Yes
 - Option C: ABC-FW-LoanReq-Work, LESCatalog:01-01-05, Availability = Withdrawn
 - Option D: ABC-FW-LoanReq-Work, LESCatalog:01-01-01, Availability = Yes
 - Option E: ABC-FW-LoanReq-, PIPFW:01-01-03, Availability = Yes
 - Option F: ABC-FW-LoanReq-, LESCatalog:01-01-01, Availability = Yes
ANSWER is 'Option D'
can someone explain?
