Alfa-Bank
RU
Last activity: 18 Nov 2015 6:30 EST
SQL Connector as Source for Data Page
PRPC PersonalEdition 7.1.9
When I create the new data page with a Source = Connector, I don't see the SQL in the Type list.
Is it a bug or is it a feature? ( SQL is present at version 7.1.7 )
TIA
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689968000/54c68a50-22c7-47d5-98f2-63df69104811.jpg?itok=I5MMyPJN)
Coforge DPA
HI ,
There is no feature for SQl to be in the list when Source= "Connector" .
Regards
Department of Planning and Environment
Hi Alex,
you should be able to see "SQL" when Connector is used as a Source. The property pyConnectorList holds the selected connector. Can you trace the activity pzGetDataSource / pzGetValidSourceTypes and check if you are seeing this list actually flowing?
I dont this this feature is removed in 7.1.9
Krish
connect-sql and connect-ejb have been deprecated from ML8 (7.1.8).
Thanks Shashi for letting us know! Is this information available in any documentation?
i was referring https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
and cant find it there.
Krish
Alfa-Bank
RU
Thanks.
But , I need to populate Data Page by external stored procedure.
How can I do it ?
TIA
Alex
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-03/0ea0d77b-d43b-4a29-9ee1-3bdd2155a6ba.png?h=d74b095e&itok=kMbovT72)
Hi Alex,
You will need to build and use a custom SQL Connector Rule Instance to use a Stored Procedure for a Data Page and then use the new SQL Connector Rule as the Data Source for the Data Page.
Henry
Pega Academy
Alfa-Bank
RU
Hi Henry,
I did it exactly as you wrote in version 7.1.7, but in 7.1.9 - subj
Alex
Pega
Hi Alex,
You can refer an activity in which you can call your Stored procedure or connect sql rule.
Alfa-Bank
RU
Hi, Bende.
Of course, I'll use Activity.
To stop using Best Practice, Pega deprecated SQL-Connector for Data Page Source :-)
Best Regards,
Alex
