PRPC 7.1.8 support for REST Connector with OAuth2.0
Has anyone tried building a REST Connector rule to connect to a Server that requires OAuth2.0/Mashery with JSON format.
Also, can we use the same from a Mobile Hybrid Client Application. The Mobile Client applications goes through a process flow (on the server). At some point in the process flow, we need to update some attributes into a third party system and would like to use REST Connector rule using OAuth 2.0/Mashery
I saw some posts that mentioned support only for OAuth1.0 is available. Want to confirm if anything has changed in the recent PRPC versions.
Appreciate any information or help on this regard.
