Need to update Connect Rest for a Json with new Json properties
In PRPC7.1.7, I used the integration wizard to create a Connect Rest rules with mapping to an Json object. Then had the wizard create rules/properties for each Json object name/value pair to have OOTB access to those properties. Since, the service owner has updated the Json and I need to add rules fro the new name/value pairs. Is there a way to do that without doing it manually or creating a new integration rule? We are now using 7.1.8.
