Maantic
Last activity: 8 Oct 2015 10:57 EDT
Encountering error while trying to execute extract rule from command line
I am getting the following exception as below while trying to execute the extract rule using a .sh file. I have used the same connection parameter in the prconfig.xml which we use for Pega to connect to the DB.
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
[java] ... 1 more
[java] Caused by: com.pega.pegarules.pub.PRRuntimeException: Error determining the mode of PRPC install from database.
[java] at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1109)
[java] at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.<clinit>(SystemSettingsImpl.java:118)
[java] ... 25 more
[java] Caused by: com.pega.pegarules.pub.database.NonexistentTableException: Database-TableWithNoColumns DLFE_PRPC715_RULE_DEV.pr4_base PegaRULES
[java] From: (unknown)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.lookupColumnInfo(TableInformationMapImpl.java:663)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.lookupTableInfo(TableInformationMapImpl.java:500)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.get(TableInformationMapImpl.java:384)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.getWithConnection(TableInformationMapImpl.java:
