ING Bank
Last activity: 25 Jul 2016 22:26 EDT
Processing a covered object in modal dialog.
We need to process child work object assignments in modal dialog. I created a control which uses pega.u.d.displaysection function and I am calling doUIAction with openassignment parameter by redirectAndRun activity. But the cross button in modal dialog is not appearing. Otherwise if I use Window.ShowModalDialog function then If I submit the assignment a new window opens. I am using PRPC 6.2 SP2. Can some one suggest any alternative
