J P Morgan Chase
J P Morgan Chase
J P Morgan Chase
Posted: Mar 11, 2015
Last activity: Apr 9, 2015
Last activity: 9 Apr 2015 11:48 EDT
Same Interaction posted multiple times
We see the same interaction(on click of a button or a link) posted multiple times in tracer. This particularly happens when the interaction has lots of steps(Activities) which takes a lot of time to load, and because the same is posted multiple times (sometimes more than thrice), this impacts the overall performance even more.
Hope anyone has observed this..!!
The Tracer shows an incredible amount of detail by default. If you look at what I pasted below you will see that INT (Interaction) column has value 238, this goes on for over a hundred rows, but because you said the interaction may even appear thrice (and not hundreds of times) I suspect I may be misunderstanding what you are referring to. I am very curious to understand what you are seeing. If you copy the trace output and post it here perhaps I can explain your results. Either way I am nearly certain that what you are seeing is not indicative of any problem but just a reflection of the amount of detail the tracer is showing.
Sincerely,
Cecil Howell
Cecil Howell, CSA | Senior Instructor | Pegasystems Inc.
Sincerely,
Cecil Howell
